Fuel tank HELP!
TXJEEP
Copper Canyon
TX
I have tried for many hours to read through pieces of forums that discuss fuel tanks. :banghead: I cannot seem to boil any of the conversation down to the reliable information I need.
I am restoring my 1982 CJ-8 and would like to upgrade to a larger than 15 gallon fuel tank.
What works and what doesn't? I see the same tank on one site for all CJ and on another as Not for CJ-8. I find 20 gallon, 21 gallon, and even a steel 33 gallon.
Can someone please point me to the right information or let me know what specifically worked in your build? Also, please see my similar question on radiators.
You can bolt in the factory 20 gallon tank no issues at all the only thing you may be seeing is that the fill hoses are different lengths which is why it may say not for scrambler. My suggestion would be to find a good used oem tank with skid and buy the longer hoses specific to scrambler. Sometimes these tanks are hard to find so there are also many aftermarket options. Just know that the bolt in area for the cj7 and 8 are the same.
Was researching tank options not long ago. As Jersey said, an OEM 20 gal tank (with matching 20 gal skid-plate) will bolt right in.
Some (most?) of the 20/21 gal aftermarket tanks are designed to use an OEM 15 gal skid-plate with 2 extension plates to lower the skid-plate.
These will not fit a Scrambler because the skid-plate extension will rub the differential cover (the rear axle on a Scrambler is slightly closer to the gas tank than it is on a CJ5/7).
That makes sense to me. Does anyone make the OEM spec aftermarket tank and skid plate?
I have a oem 20 gallon tank and skid plate. Pm me for some pictures.
I am also wondering how to check if I have a 15 or 20 gallon fuel tank in my 82 Scrambler. I am ready to order the Novak fuel pump for a LS swap.
I have not driven this CJ so I can't just run it to empty and refill.
Anyone have some measurements or is there a visual marking on them that would let me know?
I would also be looking for a 20 gallon if I only have the 15
My '83 15 gallon tank is steel.
My buddy's '83 20 gallon tank is plastic.
The 20 gal is much larger looking and surrounded by metal on all sides with plastic tank inside
15 gal look from side you can see tank. 20 gal you can't ;)
Back from garage and I have the 20 gallon tank! Another bonus is the LS motor has the regulator on it so I get by with the cheaper sending unit. Extra dough for more parts! Have to save for that radiator/electric fan combo
Sweet ! 1982 was first year for the large tank option so u got it first year. Excellent news !
I bought this fuel pump from Novak and it appeared well made. However, the motor was wired backwards. My advice is to check flow before installing everything back up into the tank, realize the mistake and then have to pull it all back down again. Novak was extremely quick and helpful on the phone with trouble shooting. Despite the mistake, I'd recommend them again. Simple mistake = 5 hours of extra work.
This same exact thing happened to me I wired it up and it blew my mind that it wouldn't pump fuel. Called the company furious, lost time getting it shipped etc. I had to fight to talk to the president to get my hours back what a freaking mess I heard that they let like 50 or so pumps get out the plant wired wrong.
Also forgot to say. Only realized months after this pic. When the body was back on the frame.
The in tank fuel pump and sender that Novak industries supplied for my stock 15 gal. Tank is 3/8ths of an inch too long, no gasket or locking washer included. Really disappointed consider how expensive they are. Having to shorten tube and bubble flare end. Also electrical connection to ground is questionable, the spade connector they use does not lock and if it comes loose you're stuck, and the fix means having to drop your tank.
Kit FSK-CJNR, in-tank fuel pump system, 1972-1986 CJ Jeeps
Good company, SHAMEFUL PRODUCT!
Mine did fit length wise but yes I agree I made my own spade connector that fit extra tight. Shouldn't have to do that I fully agree with you.
I dont have the part number handy but the one I installed last summer was a high pressure 15 gallon tank setup for a 83 cj7 for a 99 vortec 350 swap.
