Full door lock problem
Cincyjeeprs
Cincinnati
Oh
So, I replaced a broken driver's door lock assembly with a used one. Put it all back together. The latch worked fine, but when I locked it, it wouldn't unlock. I assume something came undone inside the door. Now it is stuck closed. I took the hinges off, but it won't let go at the latch side. Short of tearing the door panels off and prying back the cover plate, what are my options? :banghead:
I haven't really thought about it....but could a Slim Jim potentially help?
I had this same problem not long ago. My suggestion is to roll the window down, and remove the weatherstrip on the window sill. I made a coat hanger long enough to reach the lock mechanism and still give me room to have my head close enough to look down at the lock with a 1/4" hook at the bottom. Now you will need to locate the spot on the latch that the lock mechanism slides into. See the photo below. Insert the coat hanger in the slot and pull up. This should open the door.
attachment.php
Had this happen years ago out of the blue. I removed the interior panel, and was able to reach up and trip the lock mechanism. But truthfully, it's been so long, I don't remember exactly what I did to release it.
Got it fixed. I ended up tearing into it from inside the cab so I could see/wiggle everything. Then I fished a tool down through the top (again) per dmock's illustration. Tried that first, but couldn't quite get it without opening it all up.
At least my door hinges got adjusted a little better in the process.:shrug:
Thanks, all.
