- ORLANDO
- FL
Couple of the rivets on the strip for my metal top are out... I bought the McMaster brackets but I thought the brackets attached to the metal strip. I was thinking of cutting out the rivets, cleaning the rust off the metal and replacing it with rivets.
This is the first time I have used a rivet gun. Do I just cut the heads off the old rivets and remove the metal?
Any suggestions on which rivets I should use?
The brackets didn't come with screws/bolts. Any suggestions on which screws I should use I should use? If I am using the McMaster bracket do I need to keep the strip?
