- Laurinburg
- NC
Hi Gang,
Started up the Scrambler this morning and discovered I had no headlights. Since I goofed around with the wiring this weekend by rebuilding the speedometer, I thought perhaps I screwed something up... then I remember a friend of mine who has a CJ7 (mikegb) had a headlight problem related to his dimmer switch.
So... I press on the dimmer switch... the lights flash for a second and then go out. I step on the dimmer switch again; nothing. I stomp the dimmer switch... nothing.
So... just a little while ago I went to remove the dimmer switch and here's what I discover:
Needless to say, I headed off to NAPA to purchase their "premium" switch for $9.21, replaced the switch, and everything is working fine now.
The reason I'm posting this is just in case someone has the same problem, they can find this post via the search engine.
Joe
PS. The dimmer switch was the original one from 1982 and it had definitely seen better days
Joe
