heat and fuel gauge trouble
One ton
Fredericksburg
Va
When i start my jeep both gauges go as far to the right as they can go, like it is full of fule and temp is running hot. anyone know what i need to look for or how to test it.
You have a sending wire grounded somewhere. These gauges are designed so that the less resistance, the higher the value. If it's going to max value, then the sending wire is grounded somewhere.
better unplug the gauges until you figure out the wiring so you don't fry them.
This and this!!! You don't want to have to buy a new speedo if you don't have to :/
I unhooked the temp and it went back down, Could the temp sending unit be bad? My son filled it up with full so not sure if fuel gauge is bad.
The sensor may be bad, but if both gauges were flying over it really does sound like you've got 12V going through unchecked. You haven't done anything behind the dash, yeah?
Hopefully it's just your sensor. A working temp gauge is usually just a best guess. It's either cold or somewhere in between that and overheating :)
Curtis,
Here are some good links on the gauges. If your grounds are good and a reading of 12v it looks like it may be a bad voltage regulator inside the fuel gauge. Make sure you have good grounds including the speedo. It would normally show about 5v because the meter cannot read the flashing voltage.
http://home.roadrunner.com/~john.strenk/Gauge web page/basic_troubleshooting_for_cj_gau.htm
http://www.4x4wire.com/jeep/tech/electrical/gauges/
http://www.civilianjeep.info/Strenk/Gauge web page/QuickFacts.htm
And a little bit more in depth on the inside and working of the gauges.
http://home.roadrunner.com/~john.strenk/Gauge web page/WebPageGauges1.htm
tested another regualtor strap and same thing 12 volts. Ground is good, geeting right ohms ready from the tank, just dont know what is causing both neadles to peg out. Just going to un hook it and to he!! with it, Just drive it. LOL LOL keep a can of gas in the back if it runs out.
Curtis,
I checked out the oil pressure gauge description from the Painless Wiring Harness instruction manual from the website http://www.painlesswiring.com/Manuals/10110.pdf It is WRONG. The website Dmock posted has the correct wiring for the oil pressure gauge. Purple wire goes to the passenger side terminal and the red power wire goes to the drivers side terminal, with black for ground in between. The manual on pg 3 #19 for harness part # 10110 has the purple and red wires switched.
Just what i was thinking......Not sure but may have wires mixed up, NOT SURE that the instructins with the painless kit is right, 53 Scrambler said his instructions may not of been right on his oil gauge, and remember i never could get my oil gauge to work. to cooooled to check it for the next 7 days LOL LOL but I think some of the painless kit is wroung we had trouble with the turn signales not working and had to cut and rewire it. Like i said it aint painless at all.
This is why I went with auto meter gauges. O many problems with factory temp and fuel gauges.
It is not the gauges as much as the painles kit not having things marked right. how do we know the wires for the gauges are not crosed up in the harness.
I have been a Mechanic for almost 30 years now and I have use painless harnesses more than a dozen times. Not once have I found their wiring wrong but that is not to say it wont happen. They are pretty color specific and label the wires and tag them as well. Hopefully you have followed the site that was given previously http://www.jeeptech.com/electrical/gauges/
What I have found is the fuel sending unit in the gas tank shorts out causing the resistor strap to go bad and you get more than 5 volts to the gauges and it fries both gauges! also if you have hooked up the wires wrong on the gauges you will have damaged them too! It only takes a second with the key on to knock them out!
