Heater core replacement/heater box rebuild
AJM81CJ8
Door Breaker
Kalamazoo
Had my Scram out today. After driving for a little while I was getting smoke(steam) in the cab. Looked down and I have coolant coming out of the heater outlets. Fantastic. So I need to replace the heater core this winter. Since I already know that I have to remove the whole heater box to do this, what else should I do while I'm in there? Also, where can I get a resistor unit for the blower motor? mine is disconnected, so I'm assuming that it is toast and was by-passed by a previous owner at some point.
Do you have the blower motor upgrade?
Seems to be the "must have" in the colder climates.
Still looking for a source for the blower motor resistor. Got the heater box out on Saturday, and I discovered that the wiring to the resistor is cut, so I am assuming that a P.O. cut them to bypass for some reason, probably the resistor is shot. I'm going to check it this week with a VOM.
Can I use a Standard Motor Products RU527, fitment for 95 Jeep Wrangler? Also, any recommendations for a replacement heater core? Brands to use or stay away from?
I did a full rebuild of mine a couple of years ago following a couple of threads. I'm working a very slow rebuild, so I can't tell you how it all works. Mine is still waiting to go back in :) I can tell you that after cleaning, painting and greasing everything, the moving parts are better but still stick at points.
Blazer blower motor: http://www.jeeptech.com/body/heater.html
Full rebuild w/blazer blower motor: http://www.jeepforum.com/forum/f8/cj-heater-box-restoration-pic-heavy-975999/
Good luck!
What is the issue with finding the parts? If you go to napaonline.com they will have it... just not sure how close you are to one.
CB,
I don't necessarily have problems with finding parts. I usually do most of my vehicle shopping on-line. I get frustrated when I go into many parts stores. Many moons ago, I was an ASE-certified parts specialist. At the store that I worked at, many customers would seek me out, because I could fond stuff for them that everybody else told them was unobtainium. Most parts folks now can only tell you what the computer tells them, and if I'm going to get that, I might as well do that at home and skip the drive to the store. Anyways, all that to say that Rock Auto doesn't list a resistor from an 81 CJ-8 or the same CJ-7. I checked several other years as well, and nothing listed. I thought that I read somewhere that the Wrangler unit works just fine as a replacement. As far as the heater core goes, I know that some have had problems with inferior replacement cores failing after a short time. I'd rather not have to take the whole thing out more then once if I can help it.
OK, it sounds like you have 3 different things going on here... 1) Resister 2) Heater Core 3) the Blazer heater motor upgrade.
You asked about that, so I was thinking that was the sticky part... not the others.
The Blazer motor is what I was referring to... you get it from that part number, you cut the hole larger in the firewall and you are good to go with no other modifications.
As for the resistor, I am not sure if they reproduce that... you might have to find an OEM one.
And the heater core... some are inferior, you are right, I am sure there is information out there for who makes the best ones, etc.
Good luck.
You can use MT0972 (Autozone #) for a resistor and it will work like stock.
You can use BR430 (Napa #) which is for a YJ, and it will work as well.
Each of these will take a tweak to the hole in the duct, but they work and are easy to get.
As for heater core, I could not find a copper and steel unit I liked. So I went with a welded aluminum version I found on Summit Racing. I cant find part number right now but will post it if it pops up.
I have been running the aluminum core and autozone resistor for a few years with no issue now.
Just a quick follow up to this thread: I got the heater box all rebuilt, new core, new foam seals, sealed box up, replaced bad cables with MTS cables, Blazer motor upgrade, new resistor, and repaired all of the wiring. This thing works fantastic. Air output is fantastic and it now come out where it should. Took a while to get it all done, but it was well worth it.
What the heck man? No detailed write up with pics?
I'll try to dig up some pictures and do a quick write up, with a parts list. Been very busy, just switched back to third shift, and I am trying to get some work completed on my Scrambler before I head to Montreal for the month of May. When I get back, I have like two weekends, then I want to take it up to Ludington, MI with me, where I'll be for a week's vacation. So I need to get ball joints and front axle u-joints changed and reassemble my T-5 and get it reinstalled and tested in about 6 weeks time.
Yeah, that was basically what I followed. I did use the MTS secondary air vent and heater duct control cables as mine were toast. Also, I used 3M strip caulk, p/n 08578, to seal the heater box together. Looking back, I should have just went ahead and sprung for all of the MTS cables, other then that, the hearer is working fantastic.
I also did everything (minus the cable for the inter damper door). MTS cables are well worth the investment. Still wasn't happy for the cold weather output. Last winter installed the vintage air setup. Only used a time or two, has more cfm than the bronco blower upgrade and 3 vents that vent the air waist high. Next winter I'll have a better idea, but the initial thoughts look good. When I did the rebuild I already had the bronco motor installed (from build in 2009) so I had a improvement, but probably doesn't seem as great as yours since I got use to the improved blower motor already.
Here’s my Blazer heater motor poking through. Just cut the firewall. 3 5/8” Hole saw worked “ok”, and trimmed the last bit with metal hand shears. 56E74C05-DE18-4A7E-B42D-609A90F3B00F.jpg
