Hello from Ohio
DaveColborn
Youngstown
OH
Dave here.
I have wanted a jeep since I got a license. I owned an old '67 Jeepster Commando when I was stationed in Atlanta, GA. It was a little far gone for a daily driver and it got traded in. Fast forward about 23 or so years....I have a Jeep Scrambler bought in 2010-ish that I have been preparing to work on for the last 3-4 years. It sat under a tree in Virginia.
IMAG0087_zpsf325cdcd.jpg.html
One thing after another happened and I didn't get it back together or even make any progress. Today, my progress started. Just got it pulled to my father-in-laws house in Ohio, thanks to my friend and former employer, Matt.
Got it off the trailer and looked it over. Not exactly as I remember it. Some better some worse.
My goal is to make this my daily driver in short order, if there are no major issues in the engine and drive train. frame is in good shape and the tub is in pieces. Drive it for a while and then pull it off the road for restoration at some point if I like driving it enough. If it works out, this will be my last daily driver.
Thanks to all that have posted small projects and full restorations. I am sure I'll need the help in those posts and more.
3564cf6f-0555-483a-acd9-74542edcf1b4_zps513662f3.jpg.html
20140902_164822_zps87a897e2.jpg.html
20140902_164842_zpsc3603b9e.jpg.html
Testing/fixing photo posting.
<a href="http://s1369.photobucket.com/user/dave162/media/IMAG0087_zpsf325cdcd.jpg.html" target="_blank"><img src="http://i1369.photobucket.com/albums/ag236/dave162/IMAG0087_zpsf325cdcd.jpg" border="0" alt="Parked under a tree in Virgina for three and a half years. photo IMAG0087_zpsf325cdcd.jpg"/></a>
<a href="http://s1369.photobucket.com/user/dave162/media/20140902_164822_zps87a897e2.jpg.html" target="_blank"><img src="http://i1369.photobucket.com/albums/ag236/dave162/20140902_164822_zps87a897e2.jpg" border="0" alt=" photo 20140902_164822_zps87a897e2.jpg"/></a>
Next few days will assess what is wrong (what I actually have) and prioritize my fixes. Had oil in it, unhooked the distributor and turned it over once. Starter dragging pretty good but it turned over, heated up the battery cable.
Looks like it had been rebuilt somewhat at some point, with a fancy paint brush finish on most of the parts.
Where my jeep sat parked for 3-4 years..<a href="http://s1369.photobucket.com/user/dave162/media/IMAG0087_zpsf325cdcd.jpg.html" target="_blank"><img src="http://i1369.photobucket.com/albums/ag236/dave162/IMAG0087_zpsf325cdcd.jpg" border="0" alt="Parked under a tree in Virgina for three and a half years. photo IMAG0087_zpsf325cdcd.jpg"/></a>
tub cut in two
<a href="http://s1369.photobucket.com/user/dave162/media/3564cf6f-0555-483a-acd9-74542edcf1b4_zps513662f3.jpg.html" target="_blank"><img src="http://i1369.photobucket.com/albums/ag236/dave162/3564cf6f-0555-483a-acd9-74542edcf1b4_zps513662f3.jpg" border="0" alt=" photo 3564cf6f-0555-483a-acd9-74542edcf1b4_zps513662f3.jpg"/></a>
bed as far as I got it before parked.
<a href="http://s1369.photobucket.com/user/dave162/media/20140902_164842_zpsc3603b9e.jpg.html" target="_blank"><img src="http://i1369.photobucket.com/albums/ag236/dave162/20140902_164842_zpsc3603b9e.jpg" border="0" alt="In Ohio Assessing what needs to be done photo 20140902_164842_zpsc3603b9e.jpg"/></a>
Good luck on your build! Looking forward to seeing your progress.
Got back over today to work on the scrambler.
Got the battery charged
cleaned/gapped the plugs
adjusted the timing
carb cleaner in the carb did wonders for the idle
new gas tank hooked back up
added some gas and sea foam
changed the oil and filter added sea foam
loaded the doors, tailgate, and roll bar up in my truck for clean up and paint
Degreased and pressure washed most of it.
Starting and idling somewhat cold on it's own, with the turn of the key.
Burned oil? puffing out the top of the crank case got much less during the day, and almost to nil by the end. after cleaning the pcv and breather.
Exhaust cleaned up to where it would puff a little smoke after revving, while letting off. Bluish white.
Oil gauge (Sunpro?) showing 5-20ish. idle to revved. Seemed to run a little hot and then cool at different times. timing seemed to cool it, but then the last time I ran it it seemed to get hotter.
Tomorrow some grass to cut and making a list of things that need done/checked, and hunting through the forum to see what I can find to help. Post any questions that I can't find answers to.
Going for safety first, running and not stopping abruptly, stopping when I need it to, not catching on fire, and then will weld the tub back together as I can, paint it and drive it.
Sanded primed and painted the roll bar. Sort of a test for me painting something other than kennel/fence panels. My prep left a little to be desired, but the harbor freight detail gun and compressor did well with the fancy rustoleum. I should be able to get spray can or better results without having to go through so many spray cans.
So far $92.92 into the project (paint, gun and compressor I already had on hand)
a>
<a href="http://s1369.photobucket.com/user/dave162/media/Paintedrollbar_zpsb4c43516.jpg.html" target="_blank"><img src="http://i1369.photobucket.com/albums/ag236/dave162/Paintedrollbar_zpsb4c43516.jpg" border="0" alt=" photo Paintedrollbar_zpsb4c43516.jpg"/></a>
Did you put the SeaFoam in WITH the new oil? I'm pretty sure that you don't want it in the crankcase when you drive it. It's ok to put in and let the engine idle for a few minutes BEFORE the oil change since it breaks stuff up, but I've read that since its a solvent it will break down the oil and damage bearings etc. if driven on. You might want to check around before driving it much.
Btw, where at in Ohio?
My plan is to change it again sooner than later. Before putting any stress or strain on the engine driving. The old oil had the consistency of water (although no signs of water in the oil) so I changed the oil, and filter and put in the sea foam, and added some in the gas as well. This is mainly so I can start it and move it around the driveway.
I bought 5 quarts of high mileage oil, and a filter to put in after I work the seafoam through the engine and change the oil again. I am not sure if it is meant to be driven with seafoam in, but I have heard of people doing 150 miles or so prior to an oil change which seems reasonable to get the crap out prior to an oil change..
I am located in Youngstown, Ohio.
Thanks for the comment!!
I'm sure it will need a water pump and prob a fuel pump. Those are 2 things that usually go pretty quick if they sit for any length of time. I've got an '82 as a dailly driver while I'm building an '81 to replace the '82 at some point.Lol Good luck with your project, this is a great place for info, parts or ideas.
