Help with T5
RandyLL
1 Long CJ
Highland
IL
I posted this here because I was in a hurry for an answer. Can someone please check their transmission mount and see if the mounting rail goes on the front or rear set of holes. I'm talking about the holes in the bottom of the transmission, not the ones on the skid plate. Also, the back set of holes hang down lower than the front ones. I have the stock 6cyl. Thanks, Randy.
holes
I just went out and looked at my T-5 but it sits behind a 151 not the 6.
It uses the front holes on the transmission. I hope I am looking at the correct spot. Here is what I saw. When looking at the trans from behind I was looking at how it is mounted to the Skid plate. It has two large bolts going through the rail to the skid plate. If this is not correct then let me know and I will go look again.
Sean
Thanks for answering, but I have the 6 cyl. and after messing with it for 9 hours (since midnight last night), I think it goes on the back set of holes. However, now I have a bigger problem. When I push the skid plate up on the tran.mount bolts, the skid plate sits over to one side about 1 inch past the frame. Hence the nine hours of screwing with the engine mounts, etc. trying to figure out why. The transmission appears to be centered between the frame rails, unless it's not supposed to be. Not sure what to do now. I was planning on installing the t-case today. It's always something.
