How fast am I going?
MadGoat
Does anyone know approximately how fast I'm going with 31"s on my 81'?
On my Isuzu with 31's, for every ten miles on the speedometer I add one, so 40=44 and 60=66.....
Is there a quick and dirty conversion like that for my Scrambler?
In general, the speed you travel at depends on gear ratios of your axles, transmission, transfer case and tire size.
There can be a quick and dirty way of knowing your speed, but you have to do some math first.
Go to the link below and use either the "Speedo Convertor" if you know your original tire size, new tire size and MPH you travel at. Divide the calculated MPH by the MPH value you entered, and that will give you a percentage. With that value, multiply your speedometer value at any speed and that will give you your actual speed. As you know, with your Isuzu, you would have 1.1. That's how 40=44 and 60=66....
Otherwise, use the "Find MPH" if you know your gear ratio, transmission ratio, transfer case ratio and tire diameter and RPM.
In this case, know what your RPM is and what gear you are in when you are travelling at a speedometer indicated speed (say your speedometer says 60 mph). Enter all the information in the calculator and it will give you a MPH. Do the same math as above, using your speedometer speed and your calculated speed to get a percentage, and then multiplying your speedometer value at any speed to determine your actual speed.
http://www.mgbexperience.com/misc/tirecalc.html
Hope this helps.
It all depends what your 8 came with from the factory as far as tire size and gearing. You can either time yourself between mile markers on the highway and use that to determine your true speed compared to your speedometer measured speed or you can go to the site below to get a ballpark figure.
Vehicle Calculators
I just go behind a friend who had an accurate speedometer and called him with a cell phone.
Speedo
one easy way to know for sure is to use a GPS. You can buy one for about $100(and it will be helpful when you're wheeling in the sticks) or borrow one from a friend. The GPS has a speedometer based on your relative movement vs. the satelites. It's scary accurate, but it's best if you use it while driving in a straight line.
Good Luck,
Rod
I like the "find a friend and use a cell phone" idea. Now if I could just find a friend with factory size tires......;)
MG
On a side note: Isn't interesting how when you post 1 query you can get 7 different answers from 7 different people and all of them are accurate and correct. Just me wondering...:cool:
