How I internalized my fuel-related issues
This is the fuel sender assembly I am referring to.
I will show some pictures of the internals if you want, but there are lots on internet already. Basically, this thing puts the fuel pump down into the cup at the bottom of the assembly. The pump has an intake sock in the cup. The cup holds liquid, it is a cup, not a baffle. Also in the bottom of the cup is a syphon intake that has a second intake sock on it that fills the cup from the tank anytime the pump is running. Another way the cup stays full is the fuel return line of your system. the return flow comes in the top of the assembly to the plastic cap, and then runs down the telescoping, spring loaded mounting legs into the cup.
Looks like BOSCH version of this part is $169 on rockauto. Delphi is $185.
