I-4, I-6 or V-8???
I'm sure you can get all sorts of help here for helping choose. What you need to do is sketch out some rough details.
Budget
Desired end result (stock power, performance, etc..)
Driving habits
Mechanical ability
Etc...etc...etc.
The more info you give the more focused your replies will be. Otherwise you'll have people like me suggesting "go diesel!" :)
Cost isn't a real big issue (been saving for a while), the end result should be close to stock (I dont want to be repalcing drive shafts every weekend), I drive it like I own it and I can hold my own in a tugs engine room. I just want a nice power range with good gas mileage.
i know a few people with 302 swaps that absolutely love them. one is even a chevy guy. not many people look at weight in a swap either. the 258 weighs around 500. the 150 pontiac iron duke weighs 350 with the amc probably around the same. a chevy 350 is around 585 and a ford 302 is around 460-470lbs. a chevy 4.3 vortec would also be a pretty cool swap. theyre readily available, put out good power and weigh about 425. oh and you can also stroke a newer 4.0 out to around 4.6-4.7l using some parts from a 258 :) then youve got the cool factor to consider. ive got a soft spot for the old military jeeps with the 4 bangers so my 8 will more than likely stay 4. 6 cyl sounds great and puts out enough for most people. and almost everyone has a v8 so not as cool anymore but lots of power. big blocks can be a pita to swap into a cj. i helped someone put a 351m in a cj5 and theres a guy nearby that has a 396 in a scrambler.
