I was asked what would the maximum weight a Scrambler could hold in the back?
tom keyes
1981 CJ-8
Louisville
co
This is coming from a guy I work with who is also part of one of the county Fire departments. He is looking at adding something like a Scrambler or one of the Toyota things that kind of look like ours only with the independent truck box for carring water and a pump on. I mentioned that if you bought a stock scrambler you could replace the 4 leaf springs with heavy duty one. I thought they made some 7 leaf ones you could buy? I don't know if that would help out the load rate or not?? Has anyone found out what the max load is with heavy duty springs? Or is it all up to the axles weight rating?
Thanks
TK
Ask Fireman Hank about it. He might even have a set of heavy duty springs off the fire Jeep he bought.
You can load it up untill the springs bend or the tires pop. Probally not more than a 1000lbs safely. That is about 120 gal.
I seem to remember the sticker inside the door listing the total capacity as 1,500 lbs. That's everything, driver, passenger, fuel and cargo. Rest assured, I have never tried this, and I don't recommend it, but I'm almost sure that is the weight that was listed on the Jeep.
tom i dont know that this is what you were looking for
well i can get about a third of a cord at a shot hauling it 25 miles home.usualy around 50 mph. usualy i am hitting my bumpers above the rear axle and somtimes riding onthem only lifts off when i hit a bump that lifts the rear for a second. it controls perty good suprisingly. but i wouldnt recomend it to anyone. might be better if i had heavy duty springs. :D
Gross capacity is 4150, minus weight of vehicle, vehicle w/ full fuel and people. It isn't a lot! The number is out of a 84 manual I have.
edit- that is without the add a leaf option Rancho or someone had.
