and even pumping the pedal, it still has to go almost to the floor.. and even then, disengage is sketchy.. am I just in need of a new slave..?? or is the clutch itself getting to the bitter end..??
Not enough detail. Did you change the fluid and do a proper bleed procedure? Did you bench bleed the master to make sure it is free of air? Is the slave taking up the slack on the throwout bearing so it starts to move the clutch immediately? Check those items out first before you start throwing parts at it.
