IGNITION SWITCH PROBLEM? on my truck
CHIEFWAHO
Former SOA VP
SOA Board Member
Thayer
KS
Not Scrambler related but could be. I have and 81 Chevy pickup (short bed and pretty darn sharp if I say so myself) and am having a problem with it starting. When I try to start the truck it cranks just fine but will not start. I noticed that when I start to let off the key just a little bit it will fire but won’t stay running. Does this sound like a bad ignition switch or something else?
Replace your ignition control module and the problem will be solved, should be about $20 at autozone. I had the exact same problem on the scram, after replacing the module not a problem since.
