Ignition Switch Problems - Need Help!!!
Bryanf
Clarkesville
GA
I went out today to crank the Scrambler and as I turned the key I felt and heard a pop come from the switch. The radio and auxilary power come on but the starter will not turn. Feels like something in the switch mechanism / steering column is broke as the switch now turns easily and will not even turn off the aux. power (radio). I had to remove the steering column cover and pull on the rod that runs down the column to turn off the power. Has anyone had this problem? Looks to me like the switch is broke. How hard/easy is this to repair? Thanks in advance for any help you can provide.
The key switch drives a rack mechanism that has teeth which sometime breaker strip out. The repair is relatively simple. Search for my rebuild thread and you can read all about the repair.
Thanks, Joe. I'll check it out. Are replacement parts available at a local parts house?
Does anyone else have experience with this repair that can share a procedure, pictures, repalcement parts, etc?
