Robdesigns
- Central MA
- MA
Hello all:
I have been lurking here for a while but never signed on. I bought my 82 CJ-8 about 8 years ago and it was my daily driver until Sept. 2001 when I got into diesel cars. Up until 2 years ago it was my beach buggy to the Outerbanks. I had to move back to MA a year and a half ago to a house without a garage and have stored the Jeep under my deck ever since. I can not afford to register three cars here, and have not made time to maintain it. I feel like it is going to waste here and am considering selling it.
The bad:
I start it every other month and drive it around the neighborhood for 1/2 an hour. This morning it would not go into gear (4 speed), I assume a clutch problem. The body was very rotten when I bought it, but I riveted new floor panels and diamond plate. The frame was rotted before I moved to VA. I had 1/4" plate welded to to the side of the frame at the rear spring perches. One of the front spring mounts broke at some point. One of the last things I did to it before we moved to MA was brakes all around and a Brake booster from Off Again (Farmington, NM). The brakes are too powerful, it needs a new proportioning valve as the rears lock up way to easy. The tilt steering wheel woobles around, but the rack is still tight. The interior is trashed from a rodent infestation. The windshield leaks, but I have a replacement frame painted and ready for replacement. The (289) engine starts and runs fine, but has massive blowby and is way down on power. There is a leak from the fuel pump return line near the tank. The shocks are leaking fluid. The hard doors are in need of TLC. They are functional, but not much more.
The good:
I have a full hardtop and a 1/2 soft top with soft doors. The brakes where just done and I added a brake booster. The Eagle 389 wheels with 31" procomp all terrain tires have 5000 miles on them. I think the Jeep has the Laredo package as it has a leather tilt steering wheel, leather grab bar, clock, and tach. I have a highlift jack with all the mounting hardware. Upgraded Hella headlights with h4 bulbs.
Any advice, suggestions or purchase offers will be accepted.
Thanks,
Rob
The bad:
The good:
Thanks,
Rob
