It gets better all the time!!
Bollocky
Devoted Scrambler
Charlotte Area
Hey guys, check this out! I've been having starter issuses for a while, then a few days ago the starter would spin and not turn the engine. I bought a new one from discount (that means remanufactured :rolleyes: ) and paid $22 for overnight delivery. Well, it takes two days to process an overnight order :confused: so I should get my starter tuesday? I paid for it Thursday? Somethings not right... So anyway, I can't get my starter mount off so I took the starter apart while connected to the bell housing. Diagnosed the source of the problem and managed to put it back together so that it somewhat works. Now I can drive to work monday. Maybe.:D So, today I went to start it in a parkinglot and it over heats again (This is what I thing since the starter works when cold and when it doesn't work it's extremly hot) The engine almost starts, BOOM!, burst of smoke from under the hood! It reminds me of a dream I had... So there was smoke pouring out of the carb! and everyones looking at me.:) I push started it in reverse and drove off with out a problem.
O.k. rant and ramble over! I just thought I'd share that with you guys. Perhaps you can relate. Though, I'm wondering, what does that mean when smoke comes out of the carb?
i always heard that AMC never made computers ...cause they couldnt figure out how to make them leak oil
Yep, I can relate... I once had a 1983 Olds like that. Electric motors that don't work when hot is a sure sign that the end is near.
I'm trying to visualize push-starting in reverse... that must have been quite a dance to twist, run backwards and jump-in without the car door clotheslining you... I'm sure you made Mary Lou Retton proud. :D
Just thinking out loud, you might also want to try push-starting in 4WD-Low(with the front hubs unlocked)... that might work without the need for gymnastics. Never tried it, but it sounds logical.
Keep the faith,
Jim
Wow! I never thought to drop down the transfer case to push start it. I'll have to give that a shot. Especially if it'll be easier for me to do myself cause this thing is not easy to move! And as far as the door goes, I'm a born and bred florida boy, and I only use a top and doors when I'm going to be hauling girls in the rain. Otherwise it's topless and wide open. (It's all a subliminal message to the girls!!!)
