Finally got to drive my Scrambler today! After about 8 months of down time, I drove it around the block a couple times.
I'm waiting on 7/8"-18 jam nuts for my tie rods since the closest Chevy dealer that had the left hand thread was in Kansas City, Mo and the left hand thread are now backordered and discontinued and no one can order them anymore (several dealers told me this). Load of BS if you ask me. I'm getting them from Poison Spyder.
I need to bleed the brakes some more. I've gotten it down to 2 pumps to stop it now.
I also need to flush the cooling system since I finally got the leaks fixed (I think).
Jeff at No Boundaries is working to get me a beefier pitman arm since the F250 arm he originally got me was too big. I have the factory one on there and reamed out for the TRE so I can move it around now but I wouldn't try wheeling on it.
Last but not least I need to reprogram the computer and set the shift points for the new gearing and set the speedo (it's almost to 10 miles and I've only driven about 2).
I posed the front passenger corner up on a stack of old xj mounted tires to check clearances out. I'm thinking I'll still switch the the Ford shock towers. I had 2" to the front fender and 1/2" left on the shock and I had plenty of flex left to stuff it more. The back's got plenty of travel left since I mounted the shocks at a pretty good angle. I need to make some bumpstop extensions. I'm also not sure if I'll need an anti-wrap bar for the rear or not, I won't find out until I get these gears broke in. I probably will though.
No noticible vibrations even though I haven't balanced the tires yet but I only got it up to about 40. It drives pretty good for having welded diffs.
I'm planning on wheeling it on Father's Day weekend. I NEED to break this 2 year+ non-wheeling streak!
Sorry, this was so long but I'm just happy this thing finally moved under it's own power.
