J10 Tranny & T-Case
CJ8R
CJ8 Owner
Laramie
WY
Im not sure if this is the right place to post this but I have a quick question. This Scrambler that Im looking at buying has a 4 speed tranny and transfercase from a J10 pickup. Im pretty sure they are a T176 and Dana 20. Is that correct? I know its not a T18, no granny first.
Depends on what year the J10 was and which engine it had, if its a T176 the t case is likely an NP 208, 229 or 2?? There will be a round tag on the back of the case that tells you. Or it could be a close ratio t18 with the 4:1 first gear and the D20 transfer case. you should be abe to easily tell from underneath by looking at the cases. There is also a chance that the tranny is a t4 with one of the NP t cases.
Ok, so this turned out to be not as simple as I thought. The transfercase looks like a Dana 20 to me, so perhaps the tranny is the 4to1 T18. The owner said the tranny was a T4 but it doesnt look like one of those at all. Transfercase has the cast iron case. Now another question, would a TF727 bolt up to the dana 20? Maybe I could find someone to swap me a TF727/dana 300 for this setup.
Well have been discussing T18s over on the ifsja.org and have concluded that the 4.02 first gear T18s were only in CJ, not FSJs.
We asked of the 4 thousand some-odd memebers if anyone has a 4.02 1st in a T18 and not one responded, all confirmed 6.32 FWIW.
It could be a T176, check if the case is aluminum. Like trust said, it would be bolted to an NP208 with drivers side drop but it's the same bolt pattern as the dana 300 so that could have been swapped.
The only 727s that would bolt to a dana 20 is out of a scout. But D300s would bolt to a FSJ 727.
This makes me even more puzzled yet. I know the transmission is not a T4, and the transfercase looks very similar to a Dana 300 and I just figured it was a Dana 20. What are some distinguishing features between the two transfercases? Is it possible that it is still the dana 300 transfercase with a T176 from the J10 (though I don't think that would bolt up)? It sounds like I'm gonna have to go and take another look at it. After looking at the pictures closely and reading the descriptions closely on jeeptech.com, I have concluded it is not an NP208 transfercase. I really think the transfercase is a dana 20, and am not sure what the tranny is. The shifter on the transfercase looks like one from a Dana 300, and the shifter on the tranny looks a little different from the the one on the T176 in a previous scrambler I owned. What kind of numbers should I look for if its a Dana 20 and T176?
The easiest way to tell a d300 from a d20 is the rear output housing, aluminum on the d300 and not on the d20. The shifters are also different but the output housing is the most obvious. One wrinkle is that if the jeep (either one) was originally bought by the military all bets are off as they often got a hodge-podge of left over parts that were never combined in the civilian market.
tr
Trust is absolutely right. And it's anyone's guess what the previous owner(s) did. Just because the parts came off a J-10 doesn't mean they were factory equipment at the time of the swap.
As far as original J-10 parts, all of the above posters are correct, though I do believe a few early ('68-'70) trucks had a close ratio (4.02 1st) T-18 replacing for a short time the wide-ratio (6.4:1) T-98. Regardless, all trannys would be mated to a Dana 20 during this period (the 1-speed Dana/Spicer 21 being phased out after the first couple years of production). The good news is FSJs were never equipped with a "junk" tranny (i.e. wussy French landfill ; )). The later NP "Selec-Trac" transfer cases (all left-hand drop) are decent units, but some had funky vacuum front axle disconnects that can cause headaches in a swap.
The best thing to do would be to crawl under there and look for tags, casting marks, etc, and compare notes with the forum.
Rod
'82 SL Sport
