Jeep Weight
What is your Jeep Weight
  • 2500 lbs & Under
    Votes: 0 0.0%
  • 2501 lbs - 3000 lbs
    Votes: 0 0.0%
  • 3001 lbs - 4000 lbs
    Votes: 3 25.0%
  • 4001 lbs & Up
    Votes: 9 75.0%
  • Total voters
    12
Scott Mine
Arnaudville
LA
I went to weigh my Scrambler this past weekend. I actually learned alot from it.
First off i weighed my Truck & Trailer (Trailer had Jeep and camper just like when i go on a ride)
Steer Axle on Truck weighed 4120 lbs
Drive Axle on Truck weighed 4680 lbs
Trailer axle weighed 8590lbs
Then i took my Scrambler off the trailer and the re-weighed the Truck & Trailer.
Steer axle on Truck weighed 4120 lbs
Drive Axle on truck weighed 4620 lbs
Trailer axle weighed 3610 lbs.
So that told me:
Steer axle stayed the same
Drive axle : I have only 60 lbs for tongue weight on the truck. Load almost balanced.
Trailer axle : Jeeps weighs in at 4980 lbs ( trail weight minus me and wife). I still do not know what the camper weighs seperate from the trailer. That is a lot of work. LOL!!!!
So it looks like to me i need a little more tongue weight for a little better ride in the truck. and as a rolling mass i weigh 17,390 lbs going down the road. Again minus myself and wife.
Boy do you need to add tongue weight. You should have about 900# of tongue weight for that setup. What type of truck do you have? You may want to consider running an equilizer hitch so you can get the necessary tongue weight without squatting the truck to much.
Have no idea what my Scrambler weighs though am guessing around 4,000#. Maybe I'll run it over a scale next time I'm out driving around. Though for my rig, I don't have to worry much about the weight. 1-ton SRW with 21,500# GCWR and a GN trailer with a 10,000# cargo capacity. :D
Give you credit though, at least you have weighed the setup so you know what needs to be adjusted. Have seen too many people fish tailing without a clue on what's causing it.
Actually i run with a 02' Ford Dually Deisel. So the tongue weight is not an issue. I also run with a 28' goosneck trailer with 2 - 7k axles under it.
I figured that i needed to run more tongue weight just not sure how much to run. So thanks for giving me an approx tongue weight to start with.
With the goose neck, you want to run 15-20% of the total trailer weight on the pin. This would be 1,200 - 1,800 pounds. For me with a 18' + 5' GN, I run the rear wheels over the center of the axles. Haven't weighed it, but should be about 25% of the jeep weight plus the normal trailer pin weight which should equal about right.
Since you are talking GN, the trailer wieght is about right. We have always figured about 4,000 pounds for the trailer.
Would love to move up to about a 23+5 so I could easily haul two Scramblers.
Scott,
What is your trailer set up? Seems like the jeep only ADDS 60 pounds of tongue weight. If the Camper is on the front of the trailer, it already has tongue weight.
I seriously doubt your truck has that balanced weight distribution with no trailer.
I assume you have a 28 foot trailer with the camper on the front and the 8 on the back correct? So you have the camper forward of the axle...etc..
Weigh the truck without the trailer to get the correct figures on tongue weight..
Trailer Loaded
I think the weight distribution was correct due to the fact taht i had the Scrambler to far back and it actually took away from the camper being there.
I enclosed a pic of a pic so you can see my set-up as it rolls down the road.
Also how do you post a pic to where it shows up in the thread?
I like the "Crawler Hauler" on the front of the trailer. Looks like you could move the crawler up as much as possible. Think if you moved the crawler up so the center of the rear wheel was at the back edge of the rear trailer wheel, you would have about the right wieght on the pin. Since you are running a dually, you could go a little heavy on the pin wieght.
You could also make a box on the overhang to carry some of your tools, those heavy things you don't use on every trip. That would free up some of your deck space too.
Yea the tonge weight's probably about right. And with a dually and a gooseneck it really doesn't matter much. I've run a dually and gooseneck with tonge weights varying between about 5000 lb and 0. Never really noticed a difference. With my single wheel truck it gets a rough ride, kinda a bounce if I overload it. Figure it's due to the tall sidewalls flexing too much. It got better when I switched from 35s to 33s.
Bouncy back end
Yeah i get that to when i load my Jeep to far forward. I wanted to try and elimiate that a little. Especially here on Louisiana roads. They have to be the worlds worst roads. Don't go on I-10 between beaumont and Lake Charles. You might lose something. Like the whole trailer LOL!!!!
I agree i had too little tongue weight at that point. I pulled it from Hot Springs like that. I am glad i weighed it. So now i know to pull it up a little more so that i can get more tongue weight.
I don't think you have enough weight to cause what I get. Maybe your shocks are bad? Stock ford shocks on those trucks don't last too long.
Stock Ford Shocks
Yeah i had them on there since i bought the truck 4yrs ago. So they might need to be changed.
Hey Scott... What are the specs on the tent trailer? How long and how wide is it? How wide is the deck on your trailer?
I like the set up and I bet its convenient for sure.
Specs
The trailer is 28ft long and is 83" inside frame rails. The camper was just enough to fit the frame rails and it sleeps 5(crowded, but 5). and takes up about 6 1/2ft of the trailer floor.
2 - 7000# axles.
I am gonna try and stiffen the trailer up a little this winter. To me it moves too much. I guess with the pivot being a ball on the front it is supposed to have some play. Then again i have pulled oilfield style trailers,but did not notice the movement. Now that i am pulling one all the time i notice it. It pulls good though.
My 8 is around 4000 lbs, on the Toe rig loaded, gassed and ready to go the whole she-bang weighs in at just under 10,000lbs.
