Just exactly what is the fuel capacity of a Scrambler fuel tank?
joaquin suave
Rancho Oceano
CA
I never got a manual with my Scrambler and ALWAYS fill up when it gets to a 1/4 tank (especially because I've got a diesel motor)... I have no clue as to what the tank holds.
Don't take this as gospel but I know that some came with 15 gal tanks from the factory. There were also 20 gal and 21 gal aftermarket tanks. You can tell if you have a 20+ gal tank if it has extenders between the cross-members and the skid plate. The tank should hang mid-way down the rear differential if it is 20+ gal. If not, it is probably 15.
Metal tank is 15 gal, poly tank is 20/21 gal tank( almost fits from frame rail to frame rail)square boxed style skid
The aftermarket poly 20 gal tanks use the 15 gal skid with the mentioned extenders ( spacers)
Depends on a variety of factors: OEM steel tank (15 gallon), or OEM plastic tank (20 gallon)? What is the condition of your sending unit end? (One that is rusted out on the bottom 1" will have less access to fuel.) Is the tank dented? All tanks are going to hold a little bit of fuel in the very bottom that you'll never be able to use, and they will also have a little bit of airspace at the top that you can't fill, but the manufacturers will still advertise a the volume as opposed to the useful capacity.
I had a factory 15-gallon tank that was dented, with a new sending unit, and absolutely empty at 13 gallons. If I put 12.5 in it, I knew I was running on fumes.
When I filled my drained/cleaned OEM 20 gallon plastic tank for the first time, it accepted 19.106 gallons. I've been able to put 17+ gallons in it since then without it being completely dry. It is "empty" just past 1/4 left according to the gauge. I have a reproduction fuel gauge, and a reproduction Crown sending unit.
On my '85 CJ-7, where the tank, sending unit, and gauge are all still the original OEM parts installed at the factory, the 20 gallon plastic tank is "empty" just past 1/3 left according to the gauge.
I've never messed around with the aftermarket plastic tanks.
Bottom line: if you can put more than 15 gallons in your tank, then you either have a factory 20 gallon tank, or an aftermarket 20+ gallon tank.
