Know someone I could pay $ to finish my project???
jpdeuce
Houston
I'm in the Houston area and I pretty much have my Scrambler to a point where I can't go much further with my experience.
Most of what is left is wiring (finishing up the engine wiring, doing the dash and gauges, spark plugs and wires). I also need the rear driveshaft I have sized and the CV joint fit to my transfer case. I need a fan installed (thin electric fan b/c of space). Also a steering shaft.
I could do a couple of these things but I'm to a point where I just don't have the time to figure it all out and would just like to pay someone to get it driveable and then I can play from there.
Anyway, any ideas would be appreciated, or if any of you would be interested let me know. I'd also appreciate suggestions on how much this might cost. If anyone knows a shop I should call I'd love a contact to go that route too. Just thought I would ask you guys first.
Thanks fellas.
Give Ray or Bo a call at Jeepmasters in Austin. They do great work and could easily complete your project. I have known Ray for several years, and we wheel together 3-4 times a year. Here is there number 512-326-3555. There website: http://www.jeepmasters.com/
If you don't want to bring it to Austin, then maybe they can recommend a decent Houston shop. If you lived here I would offer to help out.
Later,
Tom
JP,
Depending on when you get your work done, I am not available to do it, but I will be in Houston 3/6-3/9 and can show you what I did with putting an electric fan on mine.
Note- do not, I repeat do not install one using the plastic zip ties that come with it or let anyone else do that. I did and after I got done wheeling Imogene Pass near Telluride the first time I about bounced mine off. The zip ties started tearing thru the fins in the radiator:mad:
I had 2 brackets made that use the same bolts that hold the radiator onto the body.
Surely there is a good shop in Houston. And Tom's suggestion is not bad if you
don't mind taking your '8 to Austin.
Just some free advice. (Probably worth what it cost ya!);)
Lots of ideas
Lots of ideas...
OK, thanks fellas...a lot of good ideas here. I will pursue some.
Also, since I picked it up on a trailer in Atlanta...I'm def not throwing out the idea of you Crash...however, it's a bit different project than zero2wow...you'd prolly have mine done over the weekend.
Anyway, I'll try some of these guys...Austin is a nothing drive compared to Atlanta...and I visit there quite a bit with family and friends there, so I will probably try those out first. Unless one of you in Austin thinks you can tackle it and wants some extra cash.
It ain't much to look at but it's got an AFW frame, 4.2L, Dana 300, NV4500...all rebuilt, new suspension, all new stainless lines...some very nice "bones"...will be a very nice running Jeep if someone could get it running...I would really hate to sell off the value that's in it...even with it looking so rough from the outside.
Thanks for the ideas, PM or email me with more if you have them.
I would suggest only using a shop that you have a direct reference from. There are lots of so-called Jeep experts around. I have seen their work, and it usually leaves something to be desired. I have been to Ray's shop many times and watched him and his techs work. They have worked on my Scrambler a couple of times when I was too busy. I am sure if you don't want to come to Austin, they can refer a good shop. I just wouldn't take my Jeep somewhere unless someone I knew recommended the shop and had work done there before.
Later,
Tom
Re: Lots of ideas
jpdeuce said:
Lots of ideas...
lol, to each there own, thats for sure. Whats good for the goose, isn't always whats goo dfor the gander (my dad used to say that to me, and I swore I would never be like him, sheesh, we can't excape it huh,lol)
Man, don't give up hope, if you desire to get it done, I hope you push for that till its done.... I think the world is a better place with more cj8's running around(can't believe i said that hahahahah)
crash is converting
I sense a conversion..........it's only a matter of time....(evil laugh then brief moment of silence).Maybe not? YOu have one hell of a toy...wait did i say that?
-Will
Re: crash is converting
-Will
:eek: :eek: :eek: :eek:
