Leaky doors?
hr223shooter07
Hope
Alright...sorry this is in the wrong section...but i had good reasoning...lol i didn't know if it should go in exterior or interior...because well, at the top of my doors....(hard top/metal doors)....there is a gap on both sides...thats the only spot...good around side and bottom...just top...this is enough for it to leak when it rains, snow inside when it snows....and a cold breeze in the winter time.....and a annoying whistle noise....well how the heck do i fix the gap...the doors are fitting tight besides that and the hard top is fiting tite...and the windshield leaks where it should fold down by the dash....any help on fixing these would be appreciated...thanks!
You might want to redo to the weather stripping.
You could fix the cowl seal with a good bead of polyurethane (I found that these things really only leak between the two hinger, ie where the cowl seal is out and up against the windsheild frame). With the doors, I think a quick cheap and possibly good fix would be to get some foam tape, or similiar product, and make a seal on the top itself. Don't make it too thick, just thick enough that it compresses a little bit when the door shuts.
I noticed on one set of hard doors I had, that the top had, over time, been bent outward slightly. How is your weatherstriping on the doors? You cowl weatherstripping probably needs to be replaced to keep it from leaking at the windshield. My XJ, after backing into a tree with the door open(don't ask, i didn't do it), Has a problem with the drivers door leaking. I put some extra foam rubber in it and now it is fine.
Here is how I install doors and it works everytime if you just need to adjust yours.
1.Take a towel and double it up, lay it on the bottom door jam and shut the door.
2. loosen all the hinges, the ones on the doors and the ones on the Jeep.
3. Center the door as good as possible and cener the Hinges.
4. I used a Straight edge to help keep the hinges straight by putting it up against the Jeep side of the hinges
5. Tighten the jeep hinges first then the doors hinges.
6. When you open the door the hinges have some play and the door will fall slightly. I folded the towel so it was triple thick and place it only on the very far side of the door on the latch side at the bottom.
7. I then re-loosened the door hinges with the door shut lift light on the door handle and tightened the door hinges back again.
Dan
