Let's see yer heep!
Scramblers
Ok the first two pics are what I am scrambling in now. Have not had much time to mess with this one yet. Sold the fj40 last week after putting much time and effort fixing her up, so now it will get my undivided attention. Some questions for those of you (all of you) smarter than I. 1. The rig is all over the place swaying. My assumptions are that the 2 inch shackles that are on top of the 4 inch skyjacker lift are responsible and must go. Does that mean that I will not be able to fit my 35s under her with just the 4 inch lift? If not then I assume I will need a body lift. Any ideas on how little of a lift I can get away with? If removing the shackles does not stop the sway, then I assume the next step is stiffer shocks and then additional leafs. Please let me know if that sounds right. Well after she stops swaying then maybe I can figure out how to pass*%**&^* emissions. :confused:
The orange scrambler was my original that I got at an auction for just over 2k (it was 100 degrees and the last thing auctioned). I sold it and regretted it until I bought another.
Any help would be appreciated
Thanks
Chad
It's about to undergo another "phase", this one will be MUCH shorter then the last one!!! LOL
I just aquired a 999 auto tranny & a 93 4.0 HO head
It's currently my daily driver since my Metro was totalled.. :rolleyes:
PS- Chad - I just put a steering bearing kit on mine cause I had scary steering & everything else steering related is new or rebuilt (except for the steering shaft which replacing it can help alot I read..)
so I suggest changing out that bearing kit, it's about 14 bucks at www.jeepdoc.com & made a world of difference on mine!
It's the one that is up close to the firewall in the engine compartment..
Also, ya, lose the long shackles & go with a 1" body lift you should be ok- maybe a little trimming or TJ flares.. hope this helps
