May I . . . Non 8 Question on Clutch . . .
Dave K.
Milwaukee
WI
To All,
I'm just putting my 98 TJ back together after replacing the clutch and I had a question . . . .
I posted this on the Wrangler Forum and am awaiting a response there but thought someone here might be able to help (trying to finish it this weekend before the snow flies!).
http://www.wranglerforum.com/f5/clutch-question-125695.html#post1794438
Thanks and please pardon the deviation here but I need an answer quick so I thought of the 8 site (and knowing a few of you are closet TJ'ers). Thanks, Dave.
I would agree with what was said on the Wrangler forum; see if you can lube the surfaces via the dust cover.
My old CJ had me monkeying with the trans alllll the time do I am overly cautious.
Sent by way of pigeon.
I'm going to pull the engine back and see what I can do. Rather have it correct even if it is just a wee bit o' grease . . . . better than going back in! Thanks, Dave.
I'd leave it alone. Those areas if they had grease on them could only make things worse. When the motor/clutch gets hot, it'll make that grease like liquid and can/will get on your clutch and contaminate it.
