RandyLL
1 Long CJ
- Highland
- IL
When I look through the Jeep catalogs, it seems like more and more of the products are for the newer TJ's only. You can pretty much order and bolt on just about any modification you desire. But there was a time when if you wanted something special you had to do it yourself. Old school. The early four-wheelers had to figure things out on their own, in the garage or on the trail. No big company engineers to design an easy fix. Where is all this going?
I was wandering what you have on your jeep that is your favorite, most unusual, or even useless modification that more than likely nobody else has. Be it a personal necessity or major improvement you're keeping secret.
The first one that comes to mind is my aux.lighting. Both front and rear switches are 3 way (on/off/on). One position turns them on. The other position allows rear lights to come on with reverse lights, and front lights to come on with the bright lights. Also, when any of the lights are on, the bright light indicator comes on. The trick was adding large diodes to the circuits so one set wouldn't feed back through the indicator and light the others. Kind of a PITA for something I rarely use. Also, the switches I used (ARB style) weren't cheap. It all seemed like a good idea at the time.
