My 8 is dead! HELP!!
The "key turning harder" sympton is very interesting. My 1978 CJ7 that I sold had this issue every so often. Not so much when it was cold out, more so when it was really damp outside. I never did sort the problem out. My buddy owns this Jeep now, so I am sure I will end up helping him fix the problem eventually:D
Battery, starter, and all battery cable connections were new and tight. All other electrical items on the vehicle would work. Solenoid was good. Just would not turn over.
I had a similar problem with the scrambler just last week. It ran fine one day; I drove it about 85 miles. The next day I got in, hit the key and nothing. The radio came on and I could hear the fuel pump. I tried a little pressure on the key to the point of feeling like I was going to break something so I stopped. I suspected I had a bad ignition switch or starter. I let it sit for a week mainly because it's been very cold and windy. I went out the other day and tried it again this time getting a good grip on the key and switch ( I have artritis). I turned the key again with a little extra pressure and it fired right up. So I let it sit for a week because i just hadn't turned the key far enough :banghead:. But it did feel like I was about to break something.
well a good charge on the battery and she fired right off. Sorry for the delayed response but been really busy at work so no time to chat. Thanks for all the help guys!!! I did try to jump it though before I charged the battery just because I thought it would be cool if it worked but the battery was too dead for it to work. It turned once and that was it until I put a charge over night on it. The weather was really bad here today as far as ice goes so it was nice to have her back on the road because in a couple of places where I saw ice I just drove off the road around it then puttered along the 2 miles it takes me to get to work.
Try this simple thing first, clean EVERY connection, new or not and tighten them down. In the words of the late great desertfox, go back to the last thing the BEEG Dummy touched first! I had a issue with new cables, ended up the zinc coating on the cable connectors (chinese) was adding to much resistance to the the system and not charging my battery. Get yourself a wire brush and some sand paper and go to town, Clean all the connections up and give it a shot.
Glad to hear it runs again...clean your conections and get the altenator checked out.
If the current weather is any indication of what the future weather holds for us, we all need to be prepaired for the comming months.
I'm glad it's running as well, however....
Now your looking at
1) Battery not charging for some reason
or
2) Battery draining when car turned off
Don't stop now or you will be stuck somewhere.
well the 8 is dead again! I guess the alternator is not working properly or something or the battery is just so weak that the cold weather we have be having lately is killing the battery. Who knows at least it is not the daily driver.
