My De-Rustification Project
Ok. Got a reciprocating saw. Used that tonight on a few more mounts. Went quickly but dulled my only metal cutting blade. So had to stop. Will get more blades tomorrow on the way home from work.
Also, have a face shield and kevlar vest for doing the work. By the way, I got the stitches out today.
You know what they say about falling off a horse. If you don't get back on, you never will. Wife says you need "just a little concealer". Coming alone good (also the face:rolleyes:)
Concealer? Ha. I wear my scars like a badge of honor. So when I tell people I work on the Heep, they believe it. I think I will go for the Danny Trejo look.
So tonight I got the remaining body mounts cut off. I used three sawzall blades. Then I finished up the last three using my grinder again with much better cutting wheels. Thicker, but much stronger.
We're any of the short ones in good shape?
Sent from my SM-G900V
No. They all were really wallowed out. The long ones were in the best shape. I almost left one of them.
I will line them up and take a pic tomorrow.
Yep. That is what I felt like wearing it.
By the way, the Heep died on my coming home last night. Same symptoms as what happened this past winter. While idling in traffic it just cut off. It was the HEI coil last time. I am suspecting the same. I have gas. I am getting 12.22 volts to the coil. I am about to go get a new coil and put it in to see. If so, what is killing my coils? My grounds all look and feel good and tight. I just redid the all when this happened in the winter.
Coil readings looked good. 9.12 ohms (at the 20k setting).
You had me at "I have gas"....not sure about why the coils died though? Are you supposed to have a resistor before the coil?
There is a resistor in the distributor and it was new in January as well. If a new coil does not fix it, I will try that.
And I did not even catch the "I have gas" comment. But I am sure both interpretations apply!! ;)
