My Labor Day Weekend Adventure!
BIG_Mark
Old Skool
Snohomish
WA
After work on Friday the 1st thing I did was to pack my Jeep, hopped in and realized I didn’t have my keys, nor were they where they are supposed to be. Since I am in the middle of moving I drove 15 miles to where my stuff is only to find out that the keys weren’t there either L
SO…I decided to make my ignition work without keys. Let it be known my ignition typically will not lock, nor does it ever need keys to start my Jeep, UNLESS I am working on it and need to turn it on and off quickly, or if I am going on a trip and don’t have my keys!!!! SO now it was really locked right and I ended up pulling the cover off the lock mechanism and drilled out the tumbler so now my key is a flathead screwdriver!
(Glad I still have my hidden kill switch) So I left for a two hour drive alone (Big no-no) to meet up with my friend who were ahead of me by 6 hours holding the camp spot.
Well about 60 miles down the road I hear what I thought was my wheel bearing squeaking. SO Its now about 9:00 in small town Enumclaw, Wa and all service stations are closed as well as the two auto part stores. I pulled it into the Safeway parking lot, pulled my bearings apart in the passenger side wheel, clean them up with WD-40 and brake parts cleaner, then realize I have no bearing grease (bad Mark, Bad!) fortunately the Safeway is on the way to the trail on HWY 410 and every wheeler in the state was stopping by with their rigs in tow. Unfortunately none of them had any grease but a guy named Bob suggested I put it together with Vaseline. So I did, and you know what it worked! However my hub and rotor were still heating up so I decided to camp off the HWY at an outlook point then change the bearings in the morning.
Morning came, I went into town bought new races and bearings as well as a new inner seal and BEARING GREASE. Changed all that, went back up the road. My rotor and hub were still heating up.
S***!!
At the top of Chinook Pass and after a bit of head scratching I narrowed the problem down to a faulty brake caliper, removed it, clamped the hose off with a vise-grip, strapped it on to the frame and continued on with 3 brakes!
Man I am glad I have four disks now;)
I made radio contact at the head of Milk Creek road and after wheeling up the backside of Manashtash for 4 hours alone( BAD! BAD!) I caught up with my friends.
Later that evening I wanted to meet up with another group of friends who were camped out near Moon Rocks.
We went down there as dusk was falling, I decided to take an unusual line up the rocks but changed my mind at the last second and was making a three point turn around when my passenger side of the Jeep went down more than was expected, all I remember was watching the hard rocky ground com up, smack the side of my front cage hoop and windshield. YEP I FLOPPED IT.
Fortunately the guys I was trying to meet up with were watching and came running down, eight guys were able to right my Jeep, I started it and got off that spot.
The only problems that arose were a broken motor mount, a slightly bent windshield frame (glass still intact!) my stock mechanical clutch linkage came apart and my lower radiator hose got a cut in it but didn’t leak.
SO we put the clutch linkage back together, used two 6’ tie down straps to keep the motor more or less in place then I drove back up the Rock where I had originally intended to!
Geeze what a night that was!
The next day we went back down to the Moon Rocks for more fun. When I got there the whole S.N.O.R.T. posse was in effect, crawling up seemingly impossible, impassable lines in their custom rock buggies and Toys. My friend “Jeepmauler” followed them up their lines in his modified Cherokee once again stealing their thunder! HA!
Well after that mauler went through a slot in the rocks that I was looking at, after some body scraping and tire turning he made it through, since I had a broken motor mount I wasn’t exactly anxious to go through that spot but did anyways after “Jeepless” went through in his just completed Cherokee that he had only wheeled one time before.
After entering the line I knew I was right about not having enough clearance under my rig, I got high centered on a rock that I was eventually able to get over with the help of a little “Road building 101” after that it was up a 6’ rock wall and while being at a 40° angle (nose up) and turning hard right I made it to the exit of this line, not before coming down on the side of my Jeep and rocker guards, thankfully the damage was minor to the body and the rocker guards help up just fine.
We ate lunch then spent the rest of the day in the trails around camp then headed back to the grill for a slew of Johnsonville brats basted in beer (washed down with Beer too!)
The next morning we had a clear day to head back to Seattle (about 100 miles) since we didn’t feel like sitting in traffic on the freeway we went back via the Nacheese trail. There is nothing like driving the Nacheese. Though it isn’t the hardest and most technically challenging trail, it is long (like 40 miles) and takes you up and over the Cascade mountains tracing a wagon trail used by the early settlers. It offers many beautiful views of Mt. Rainier and the surrounding mountains. Along the way we met other wheelers, motorcyclists, quads, and two hikers that left Mexico in April and were hiking to Canada! You just never know who you will meet, as usual most people were friendly and interested in our trip and where we came from and were going, as well as how to get there. That took us about 6 hours and made our trip home a nice endurance trail run. Naturally my alternator died so I had to keep the Jeep running all the way home.
This journey was awesome, it’s trips like this that make me happy to have a Jeep that can handle the ride and get me home, as well as get me out to some awesome places most people will never see.
I hope all you all had an opportunity to get off road this weekend in your respective rides.
Attached is a Parked pic of my Jeep at the base of the Nachees right before making the final 50 miles home. As soon as I get the moon rock pictures from my friends I will post them.
FYI if anyone wants to go to Moon and Funny rocks this year we will be heading back in late November (22-24) for the final open weekend of the area to do some mud runs up the hills and through the tight trails. All are welcome!
Mark
Sounds like a memorable trip, glad you were okay. I went out with a friend who just bought an old XJ and has spent the last three months getting it trail ready. He had a great time in it and the Jeep performed well without anything breaking, so it was a nice weekend. As soon as i get the pics i'll probably post too.
Mark - Always enjoy your posts...looking forward to the pictures!
-Mike
Finally some Pictures!!
I finally got some pictures.
Non of me flopped but in this One I am stuck (High Centered, darn 34s!)entering the obstacle.
After a little road building 101 I got out of that mess and entered the base of a 5.5' crawl here I am rounding the corner.
Here I am getting up on the wall.
as I said its at least 5.5' tall.
this picture was taken from above me looking down. this is not a side shot.
Here is the exit photo.
My rear tires are where my front ones were in the previous photo. The exit is to my roght (hard right) At this point I was hving MAJOR carb issues. So bad I decided right then and there to upgrade one way or another to fuel injection. But hey that's a whole other thread!
Enjoy the pics guys.
Hopefully there will be more but I knid of doubt it.
Mark!
