need 304 info..
K9rockydog
Glendale
Az
Hi, guys.. aint been around since parting with my scram.. (moment of silence, please..)
but I still have a cj7 with a 304.. It USED to leak like a stuck pig..
finally got tired of this, and replaced rear main, oil pan gasket, rebuilt oil pump.. but still leaking around oil pump/time chain cover..
my question is this.. I saw somewhere before, a better oil pump body with the spacer, and an aftermarket T-chain cover..
anyone know where I can get those to finish this thing off so I can stop staying awake nights, wondering how to fix it..????
I've been through three AMC blocks, three different timing chain covers (including two aftermarket), at least four oil pump covers, and mine still leaks at the front. I had a Grand Wagoneer with a 360 that did as well. I got everything else sealed up on that one, except the oil pump. The best solution I've read about for a street-driven Jeep: zip-tie a tampon where the worst part of the leak is, and change it each time you change oil. (This won't work if you take it wheeling.)
That's why I have a 401 sitting on the shelf and will probably put a 350 in the build instead. Bulltear seems to be the best according to the amc forum. But they can have their problems also. http://theamcforum.com/forum/ They will have the info you are looking for.
