Need Advice on Replacing Clutch Slave Cylinder-Leaking Like A STUCK PIG
summerj
Orlando
Fl
Hello All
My Slave cylinder is leaking like a stuck pig. Now I have Air in the line because it went bone dry. I replaced the clutch master cylinder last summer. How hard of a job is replacing the slave cylinder? Do i need to remove tranny. or is it an easy fix? ( I am going to tear into it this weekend.)
On a side note.... I searched the forums on "hydraulic clutches" and came across lot of folks converting over. I would not do it -its not worth the agravation- but thats my opinion. From someone owning both types of systems. though I like the smoothness of the pedal action with the hydaraulic set up..... if I had to choose between the two-I would stay old school.
