New Axles project -Wagoneer Front and Scout rear?
did you bolt it to the axle flange or weld the bracket to the tube?
I used the same bolt locations as the drum backing plate with grade 8 and locknuts. I cut the backing plate down to be a small ring so I can still use it as a bearing/shaft retainer.
