New engine recommendations
Was this motor built with a 3-angle valve job? I don't think 3-angles are really as prevalent as people may think... What was the compression on each cylinder? If the valve seals and holds compression, I'd say the head is NOT ruined. But I missed the preface to this story...
The re-builder who looked at it says he can't put new valves in because that's already been done once, and it's now too close to the water jackets.
I'm curious, with the exhaust valves pounded so badly, but the intake seemingly more ok, what does this indicate?
I get that the exhaust valves get all the heat. But it would seem that if there was a set-up / geometry / cam issue, that would have affected all valves equally, not just the exhaust valves.
Possibilities:
(1) Engine running too lean?
(2) There's a possibility these exhaust valves were oversized and maybe there was an installation issue in the first place.
(3) I simply overloaded the engine, hauling a heavy load & driving all day on long hot summer days over mountains, etc.
What else?
In addition to new intake manifold, and new exhaust system, Would this require:
- changing engine mounts?
- New computer?
- New wiring?
- New radiator
- New bellhousing/adapter
- Anything else?
I'm sure there is someone on board that has done a 350 or 360 swap that can answer better than me.
You are correct that it would take Ex manifolds.
It already has intake manifolds & FI tech fuel injection mounted.
It needs an external balance flywheel. It says it mounts up to a 727; so I THINK it would bolt up in a CJ application?
It needs fuel injection style high pressure fuel pump system (you may already have if you were running FI on the 4.0).
Says it needs an ignitiion box....
ATK High Performance Chrysler 360 Magnum 320 hp Stage 3 long block crate engines with EFI are perfect for a street cruiser, and offer great street ability, stock idle, and good power. Based around FiTech Self-Learning EFI systems, these engines come complete from throttle body down to the oil pan. The only thing you will need is to supply is the fuel system--in line, in tank, or the FiTech Fuel Command Center. Plus they are dyno-tested with your EFI system and ready to go! These Stage 3 engines with EFI set your vehicle up for better drivability and trouble-free cold starts with no tuning required, regardless of elevation, driving habits, or part swap!
