jeepit
- Dillon
- IL
I was worried about that, and in fact the pass side had already tweeked to where the door would not close. Thats why I did one side at a time and only removed and replaced metal as I went. I did outside under the doors first so the body would retain its shape. On the pass side I had to put wood between the dash and rear of door frame to hold it to the correct size. then on the inside I only removed floor and supports on one side at a time. there are 3 body mounts on each side under the cab, the ones under the rear door posts were the only one I removed and replaced. The other 2 held everything in place. Well I guess that will or won't be when I put the doors back on.
