Nutter Bypass
JimB
Anna
Tx
As most of you will note I just joined the forum. Just received my Scrambler last Thursday. It's already equipped with an HEI ignition, Holley carb. and Clifford intake. Should I still do the Nutter Bypass?
:cheers:
If it's already got all that done it most likely has had the Nutter done already. Nuttering bypasses the computer controlled carb, so you should be good to go!
Nah, the nuter uses your stock ignition but bypasses the computer. With the HEI distributer your not using the stock ignition box on the drives inner fender. And with the holley carb you don't have any of the computer wires hooked up. If it hasn't already been done you can clean out a lot of your engine compartment.
