O.T. Intake manifold leak on DD
rb85cj7
Temple
Okay, my wife drives a 2001 altima and has been idling really rough. So, after a little help from google I found that this model is prone to intake leaks around cyclinder #4. I got out the old B-12 and waited for the rough idle and sprayed it around the intake at #4 and sure 'nough the idle smoothed out and all was well.
Now here is the question, What does this effect if i don't fix it right away? It runs fine up and down the road, just has a rough idle. I love fixing my jeep but i can't stand compact engine bays.
Any thoughts?
The short answer is, not long. The longer you drive, the worse it will get, and the worse mileage you will suffer as the ECM tries to compensate. The excess gas may not all be burned, either, so you may have some cylinder wash.
The long answer:
My wife drove her '89 XJ DD (OBD1 4.0) for almost a year before we fixed a RAGING intake leak. I went nuts trying to track it down, removing and cleaning the TB, IAC, TPS, new MAP, MAF, etc.
It all came down when a NAXJA member suggested putting my hand across the TB and see if the engine stalled. NO! It ran GREAT! Sucked my palm down square across the intake, and the IAC never moved a mm, but the engine just hummed along. HOLY CRAP! :eek:
Torqued the manifolds, and all has been well since then. Mileage has improved, idle has settled down (was incredibly high, since the O2 was reading too lean, it was dumping gas to compensate), power has increased. We just logged 18mpg over a recent road trip towing a 4x8' box trailer loaded with camping gear.
So, that said- it will run as is, but not well, and your potential for damage goes up. Yes, it's a PITA, but getting it done sooner rather than later is always good.
