If you are looking at cost. The Rustoleum is actually not too bad of a paint.
In the Semi Gloss or Flat it can be had very reasonably, and will spray OK. Not going to give you a great finish, but if you are looking to re-create the military type finish then this is pretty good. Equipment for spraying will affect the finish, so use a good gun and technique, and you should get a decent job.
If you can find it in their "Industrial" line then go for that. It is a little better version of their paint.
For those guys looking at the new trend of Hot Rod Black. Their Semi-Gloss black is a nice version.
Thins with mineral spirits too, for a low cost application.
Carl
