An awful lot of these discount winches, the harbor freight, the collins bros, etc and perhaps this one, I don' tknow, are made by the Wang Winch Co in China and are simply fit with different color pices and different labels. I understand that Wang is like the chinese Warn, ubiquitous, but Idon' tknow the quality nor the reliability. Could be fine, might not. For emergency use only it is likely fine but I would check everything very carefully during installation, Scrambler 81 was actually lucky that the cable came apart, had it not but had that poor a connection and he tried to use it extensively either the power lead would melt or the battery terminal might melt or it all might catch fire, and you d still be stuck to boot!
The 8274 is a great winch, I've picked up two used ones at different times, neither was close to $299 but neither was close to full retail either. I've also had an M8000 and a Ramsey REP 8000. All were fine for my use, the ramsey was like $399 but years ago.
so what does all this mean, nothing, but if you think this winch is at all suspect, at all, I would spend about the same $$ for a 3 or 4 k warn ATV winch and snatch block, etc, then build a hitch mount for it and just keep it in a box in the bed for the odd occurance when I needed it. you will likely never need a long hard pull in a solo situation, if you do need a long hard pull its likely you'll be in a group with at least one bigger winch. If on the other hand, you compare the specs with a comparable Warn or Ramsey or ??? and they compare favorably then go with it, take notes, and let us know what you think
