Oriental Red Original Paint refresh with NOS
So what different about dealer air vs factory air? Besides the configuration of belts and brackets.
That's pretty much it...some other differences too but that's not what this thread is for :)
Huh. I've had two with the Alt up top and both had the lines going where they were supposed to.
That's cause your dealer or whoevers dealer it was had enough sense and lack of laziness or wasnt in a rush etc to use the factory access plate rather than hack the firewall... :wave:
Jersey Jeeps hooked me up with hardest part of factory A/C puzzle.
Thank You :)
This is a dealer install kit that is on my CJ-7.
It's been this way for long time without rubbing upper radiator hose, but makes me nervous.
Can't get smaller belt on as compressor will hit alternator.
Also got a NOS 30# bottle of R12
The CJ system uses 2.5# of R12 & 7oz mineral oil
Can you post a pic of the the front of the cj unit.
Since Mud Scrambler is nearly completed, and almost bought 86 Red Laredo 2258 miles but it has antenna in wrong spot last night... Starting to think about finishing 82 Oriental.
Here's pic of front of JJ's flawless A/C for Oriental.
I also learned from trying to find NOS A/C outlet louvers for this #2 in world CJ that there is difference between under dash evaporator factory installed - VS - dealer installed.
So A/C outlet ducts are different even though both mfg. by American Air in Ft. Worth, TX . More trivia.
Interesting. So which ones does cjlaredo sell on ebay? The dealer installed?
That red Laredo has the same antenna/ location as my 85 medium green metallic renegade. Bad dealer installs?
Not sure which aftermarket version he sells.
I just bought some turn signal housings from George for Mud Scrambler and like his spring loaded bulb retention design.
Yea some dumb dealership just put antenna where they wanted and installed a crappy cassette player on the otherwise fine low mile 86 CJ-7 Laredo.
