The old 7.3s with no turbo were good engines. The only problems ever with them were the occasional glow plug going out and injector return lines need to be replaced every 7 years or so. If you get one, take it to a diesel shop and have it tuned. The injection timing will likely be a few degrees behind specs, have it set to specs or 2 degrees advanced for more power, more mileage, and more noise, it will wake the neighbors with the startup idle in the winter. Those engines are all mechanical and easy to work on. They can get over 20mpg. In 94 ford offered the old style 7.3 with a turbo, these had problems with burning a hole in #8 piston, and hardly had more power than a non-turbo. The powerstrokes also started in 94, they do have alot of power, but aren't very reliable with $250 electro/hydraulic problematic injectors, and 2 piece fly wheels. Around here a early 90s dodge diesel costs almost twice what a ford does. Up to 93, dodge and ford front axles were both normal d60s, with the ford having a high pinion not being of any real advantage. After that, dodge went to a funny 60 with unit bearing hubs, but I don't think they give many problems. If you get a dodge, try to get one with 3.55 gears.
