Overheating Issues
breckwrecking
Narrow Tracker
Kittery
ME
I have a '81 8 with a fuel injected 4.2L. My radiator and water pump blew last summer, so I replaced both of them. Since then I have lost all heat to the heater core, the engine overheats, it sounds like the radiator boils and it will whistle when it gets hot. Coolant will also spray out of one of the hoses going to the heater core. When I let the engine cool down and open the radiator cap it sounds like it is pressurized. I've flushed the heater core, and also swapped the hoses to check directional flow but it still does the same thing. Kind of lost at this point. Any help or ideas would be beneficial. Thanks.
I think there are multiple versions of that water pump, depending on the add-ons (ac condenser, etc). Buy the wrong one and you're pumping in the wrong direction.
What sounds more likely is that you have a buggered up heater core blocking flow. That may very well be the reason you had trouble last summer. First thing I'd do is bypass the heater core and see if there's any improvement. If so, you know what to do. If not, the pump is the first place to check.
When you flushed the heater core, did you run a garden hose through it? If a hose can run through mostly unrestricted you should be alright there.
The system should be pressurized when running. Did you change your thermostat?
As stated above, serpentine vs vbelt water pumps turn opposite directions.
There is also the possibility of air in the system. I normally start and run the engine with the radiator cap off. When the thermostat opens at operating temperature you can add coolant until the radiator is full.
Check for exhaust gasses in the coolant. You could have a blown head gasket.
