Parade Help!
ElDee
SC N8IV
Suwanee
GA
Hey fellas - for those of you who don't know, I am a total Jeep newbie (this question will prove it). I am pulling a 16' open "landscaping" trailer 12 bails of hay, 3 adults and 8 kids in a parade tomorrow. I have 33" tires and a 258 w a t-5 The question is this:
If I were concerned about the ability to pull the weight, would it help to run in either 4L or 4H and if so which one?
The reason I ask is, it seemed like I had to ride the clutch a couple times to get the Jeep to start on an incline .... I can't be certain that I won't find myself in that position along the parade route.
Thanks
Luke
4lo with the front hubs unlocked.
That will let you run super slow and not show the load when you take off. You still might find your self having to feather the clutch, but it should not be as bad.
Definately watch carring that trailer to the event. I might even thing of having someone else with a full size truck get it there for you and then just use the Scrambler for the parade. At slow speeds it will be fine. But at highway speeds you can get into trouble quick.
Carl
Just curious, how does the 4lo have an affect if the hubs are set to 4x2? Certainly not questioning your advice just hoping to learn something.
Thanks
Your axle shafts still spin at the reduced speed but since the front hubs are unlocked the wheels don't spin (only the rear wheels) Web wheelers will tell you this screws up the splines on the hubs but I've never seen any adverse affects in the real world.
If you run in Low range with the front hubs locked on pavement it will be extremely hard on the front end when you turn. By using “Low” range you can add more torque, thus being able to tow the trailer easier. In essence you can add more power with out un-wanted ware on the front axle.
SC
Ditto on the 4 low with the front unlocked. With the 33's you are probably hurting for gears anyway. Can't remeber if you told me they changed them out or not when it was built. Going in 4x2 with 4 low you are basically changing your gears. Hey, TAKE SOME PICS!!!! I love seeing beautiful Jeeps in Parades.:D
Actually, if you run 4-LOW, hubs locked, on hard pavement, you CAN bind up the driveline to the point the vehicle will not move. You then have to "unwind" the driveline by driving in reverse. It's possible to break the weakest link (u-joint or whatever). The reason this binding occurs is because it's virtually impossible for the tires on both axles to be EXACTLY the same diameter, therefore the effective axle ratios can never be the same. One axle HAS to slip, if it can't, it binds. I've had a truck bind to a standstill because I forgot to unlock the hubs. Duh!
There is debate concerning unlocking your hubs and running in 4-Low. Some say it transfers excess load to the intermediate gear of the t-case, but I've never heard of this happening in real life. You're in a parade and won't be doing anything dumb(not that you would, anyway). The engine will just spin a little faster. You should be fine. Unlock the hubs and use 4-LOW.
Paul
Rember when we loaded it up on the trailer at my house. I put it in 4-low but did not lock the front hubs. It allowed me to go slower up the ramps and have more power in doing that.
Basically you will be spinning the drive line and front ring gear. But with out the hubs being locked the inner axels cannot transfer power to the hubs and force the front wheels to turn. They will turn because they are in contact with the ground and the jeep will be moving.
Biggest thing you are trying to avoid is driveline bind because of the differences in front and rear travel of the wheels. They will always be a little different. Now on wet, icy, or muddy road the wheels can slip and equalize tension. On hard pavement you cannot. Also having the front hubs lock will make the front wheels turn equal lengths which is not what happen swhen you make a turn.
So best thing is to use the reduction gear of the transfer case. Yet keep the drive to the rear wheels only for turning and bind reasons. Since you do not have atwin stick with the option of 4 wheel rear drive only, you must keep the front hubs unlocked to accomplish this.
BTW, you cannot do this with a TJ or YJ unless you have swapped out to a Disconnect type hub like the CJ or older style truck.
Carl
