Planning 4.0 Head & FI swap
To try and answer some of your questions I think it would be easier for you to decide if you are wanting to go OBD1 or OBD2. OBD1 is obviously a simpler system (5 wires to fire).
Regardless if you go OBD1 or 2, you will need the distributor for that system. You will have to replace your HEI unit.
I am not familiar with the OBD2 wiring but it will vary from that in the OBD1 Jeeps. I think there are even several variations in the OBD2 wiring over the years it was used. Someone more familiar with the OBD2 wiring can chime in on this. I think BigWalton used a '97 OBD2 wiring harness in his postal, might check out his build thread.
I'm not sure if the OBD1 ECU will match up to the plug on the OBD2 wiring. Again, I think it would be easier to go either with OBD1 or OBD2 than trying to mix and match wiring/parts between them. Trying get get an OBD1 ECU work with an OBD2 wiring harness and various sensors sounds like it couple be a potential nightmare!
I run the 7120 cylinder head. Looks like the 0630 has similar flow rates as the 7120, but lacks the provision at the rear for the engine temperature gauge sensor. Like Ron said, I think a great deal of the gains come from the MPFI. But the 7120/0630 heads is still a likely improvement over the 258 head.
Good info on this page:
http://www.jeep4.0performance.4mg.com/tech_specs.html
Sent via smoke signal
Definitely going OBD1.
Anyone know if the OBD1 and OBD2 distributors were the same?
Looks like they are different....
I will need an alternate location for the water temperature gauge sensor to mount.
