redscare
- LA County
- CA
Alright. So I go to get in the 8 today and turn the key. It starts up fine but then after a few seconds, dies off.
I started it again, revved the engine a little more this time and it still died off after a few seconds.
In trying to determine the problem, I noticed that I couldn't see any fuel being spit into the carb whenever I pushed the pedal. I poured some gas into the carb started it up and it started and died again after a few seconds. I then found that the linkage which controls the choke plate isn't engaging. There is a clip which holds the rod into the groove (see pic), but I guess it's not holding it close enough because whener I gas it the choke plate doesn't move even the littlest bit. Do you guys know how I can fix this? or do you have any other ideas as to why things aren't going the way I want them to?
I don't really know what I did though. I disconnected the fuel line from the carb (i had just filled up so I knew there was gas) and tried to start it. It didn't put too much fuel in the jar the first try, so I twisted the jar around and tried again and the fuel came out just fine. So I hooked the line back to the carb and checked again to see if any fuel was getting into the carb through the venturis. This time there was and she started up beautifully. So what was it? Just a clog in the line? I honestly don't know what I did, but I'll take it.
