trust
PITA
- White Rock
- NM
The Healthy Forests Restoration Act (HCRA) will be considered before the
full House of Representatives on Tuesday, May 20th. Recreation resources and
access suffer when our National Forests are allowed to burn. It's important
for recreationists to weigh in on this debate!!! The House Resources
Committee could use some letters from diverse recreation groups supporting
the HCRA. Letters should be faxed, on your letterhead, to Congressman Scott
McGinnis's office at fax number (202)226-0622. If you want more information
on how you can help, call his office at (202)225-4761.
Perhaps even more important is to get thousands of recreationists to call
their Congresspersons in D.C. You can call the Capitol switchboard at
(202)224-3121 if you don't know the number or even who your Representative
is. Just tell them what kind of recreation you are involved in and that you
want them to support the Healthy Forests Restoration Act and tell them why.
BRC will be e-mailing our entire alert list to get the word out. Please
consider doing the same to your distribution list. Thanks!
(the following is from a media release we sent out on this issue)
“Forest fires resulting from a lack of active timber management have severe
impacts on recreational access,” says BlueRibbon Coalition Executive
Director Clark Collins. “In addition to the negative impact on scenic
values, most fire damaged areas are closed to recreation access for years
after a forest fire. For this reason the BlueRibbon Coalition is an
enthusiastic supporter of the President’s Healthy Forests Initiative.”
Clark L. Collins
Executive Director
4555 Burley Drive, Ste. A
Pocatello, ID 83202
ph.(208)237-1008 ext. 101
fax (208)237-9424
www.sharetrails.org
Clark L. Collins
Executive Director
Pocatello, ID 83202
fax (208)237-9424
www.sharetrails.org
