Poor planning - Funny Stuff
Stouttrout
Registered Jeep Nut
Sour Lake
Tx
"Dear Sir:
I am writing in response to your request for additional information on the
accident reporting form. I put "poor planning" as the cause of my accident.
You said in your letter that I should explain more fully and I trust that the
following details will be sufficient.
I am a bricklayer by trade. On the day of the accident, I was working alone
on the roof of a new six-story building. When I completed my work, I
discovered that I had about 500 pounds of bricks left over. Rather than carry the
bricks down by hand, I decided to lower them in a barrel by using a pulley
which, fortunately, was attached to the side of the building at the sixth floor.
Securing the rope at ground level I went up to the roof, swung the barrel out
and loaded the bricks into it.
Then I went back to the ground and untied the rope, holding it tightly to
ensure a slow descent of the 500 pounds of bricks. You will note on my accident
form that my weight is 135 pounds. Due to my surprise at being jerked off
the ground so suddenly, I lost my presence of mind and forgot to let go of the
rope. Needless to say, I proceeded at a rather rapid rate up the side of the
building.
In the vicinity of the third floor, I met the barrel, which was now
proceeding in a downward direction at an equally impressive rate of speed. This
explains the fractured skull, minor abrasions, and the broken collarbone, as
listed in Section 3 of the accident reporting form.
Slowed only slightly, I continued my rapid ascent, not stopping until the
fingers of my right hand were two knuckles deep into the pulley. Fortunately,
by this time, I had regained my presence of mind and was able to hold tightly
to the rope, in spite of the excruciating pain I was now beginning to
experience.
At approximately the same time, however, the barrel of bricks hit the ground
- and the bottom fell out of the barrel. Now devoid of the weight of the
bricks, the barrel weighed approximately 50 pounds. As you might imagine, I
began a rapid descent down the side of the building.
In the vicinity of the third floor, I met the barrel coming up. This
accounts for the two fractured ankles, broken tooth and severe lacerations of my
legs and lower body. Here my luck began to change slightly. The encounter with
the barrel seemed to slow me enough to lessen my injuries when I fell onto the
pile of bricks, and fortunately, only three vertebrae were cracked.
I am sorry to report, however, that, as I lay there on the pile of bricks in
pain, unable to move and watching the barrel six stories above me, I again
lost my composure and presence of mind and let go of the rope."
That's a classic. Still makes me laugh every time I read it.
The Mythbusters show on The Discovery Channel actually re-enacted this famous story on an episode.
