Powertrax Lunchbox install help.
STSFCTN
Well-known member
Silver Member
Centennial
CO
I installed the Powertrax Lunchbox (street version) locker in my AMC 20 with 1 piece axles last night and was about to put the cover back on when I decided to test the installation. In neutral, on jackstands, I spin the tires and both wheels spin in the same direction. In gear, it just locks up, no movement. I took out the main pin to determine where the bind up was coming from and with the pin out and in gear it is the ring gear that does not turn. I have uninstalled and reinstalled and had everything marked with a sharpie prior to installation. What am I doing wrong?
out of frustration, I asked AI and this is what it said- call me crazy but is this the solution?
Your diagnostic work has actually pinpointed the problem very precisely. The fact that the ring gear itself will not rotate with the cross shaft removed tells us the bind is not inside the locker mechanism at all — it is happening between the axle shaft spline ends and the Powertrax couplers. This is a well-documented and specific issue with one-piece axle conversions in the AMC 20.
Root Cause: Axle Spline Ends Bottoming Out in the Couplers
Here is what is happening mechanically. The Powertrax No-Slip couplers are designed with blind-ended spline bores — meaning the spline pocket has a closed bottom. The factory two-piece AMC 20 axle shafts are a specific length that leaves a small gap between the spline end of the shaft and the bottom of the coupler bore, allowing the coupler to float and function freely.
One-piece aftermarket axle shafts are frequently slightly longer in the splined section than the original two-piece inner shafts they replace. When you slide the one-piece axle in, the spline end travels all the way through the coupler and bottoms out hard against the closed end of the coupler bore. This forces the coupler outward and jams it solidly against the carrier housing wall, effectively welding the entire assembly together. The result is exactly what you are seeing:
  • Both wheels spin in the same direction out of gear (acting like a spool).
  • The ring gear cannot rotate at all with the cross shaft removed, because the couplers are physically wedged tight against the carrier.
The Fix: Shorten the Axle Spline End​
The solution is to shorten the splined end of one or both axle shafts so that the tip of the spline does not bottom out in the coupler bore. You need to create clearance — typically 1/8" to 3/16" (approximately 3–5 mm) — between the end of the axle spline and the bottom of the coupler pocket.
I also researched that I should not need the thrust block with one-piece axles?
Is that true?
ok this is what AI said it it pulled the answer from this site-
What Happens If You Remove It With One-Piece Axles​
Removing the thrust block with one-piece axles is the correct and recommended procedure, confirmed by multiple sources:
  • CJ-8.com (user with Moser one-piece axles and Detroit Locker): "When installing 1 piece axle shafts, you need to remove the thrust block from the differential in order to prevent excessive preload on the outer bearings."
  • JeepForum.com (AMC 20 end play thread): "The diff thrust block is not needed in 1 piece axle installations and can be removed."
  • TheAMCForum.com (Powertrax No-Slip install thread): The installer confirmed "The factory thrust block is not used when installing this unit" — and the Powertrax installation manual for the AMC 20 specifically instructs you to leave the thrust block out with one-piece axles.
Removing it causes no negative consequences with one-piece axles because those axles do not rely on the thrust block for end play control at all.
