Project Scramblicon Process, or maybe Scrubicon
Jimbob
Germantown
MD
Well a month and a half later and I havent made half the progress I wanted to. Encountered a fair amount of putty(expected) in the rear panels and had to put several patches in (ah metal) including fabbing up new wheel arches. Had to do some metal patches on the sides below the Jeep emblem. Again not bad just slowed me down. Right now the main tub is in primer after being POR15ed then tiecoat primered. Hopefully this weekend I will get to POR15 the undercarriage. TF904 is almost ready to go in but I want to get topcoat on it first. Herculiner is purchased just need to roll it in. Luckily it had a new AGR steering box and pump in it when I bought it.
Started with
Hope to have update pictures this weekend. I am still not complaining for $2200 and a perfect frame.
However, my plans for the finished product have changed somewhat. Originally I had intended to make the vehicle very near stock. But given I have put a few patches in I am going to take it a little further, not to a dedicated trail jeep (hey thats what cheap YJs are for!) but more in the range of capability of the Rubicon (hence the Scrubicon joke). Essentially a daily driver that I can do some mild to moderate offroading.
Current Plans (In progress):
Body:
Thinking about adding rockerguards instead of repairing the factory aluminum trim.
Gastank and Oil Pan Skid plate
Wilderness System front bumper
??? Rear bumper (want to be able to tow a boat without having a low hanging hitch)
Herculiner
Nissan Camoflague green (sort of a semiglossy olive)
Engine:
4.0L head then MPI.
Transmission:
Rebuild 904 (hey it was dirt cheap and has been built much stronger than stock)
Still deciding on a shifter, was going to do a lokar but dont really like the feel of them. Thinking of building a small custom console and putting a hurst (Dual Gate?) or B&M in).
Transfercase:
Does it get any better than a Dana 300! I dont need lower low range so I will leave that stock. Would like to do a true twin stick conversion though and get front wheel high. (Do I need it no but hey...........)
Axles: Got to have lockers! If they made it I would have just put a Truetrac LSD in the rear but probably will go with ARBS with 3.73 gears. One piece axles for the old AMC20.
Tires: Relatively small, 31 inches or so.
Interior: Tuffy Stereo console, I am open to ideas for speaker placement. I am not the biggest stereo fan but would like to have a good set of speakers in the dash, a second set and if I can figure out where to put it a small sub. Small amp. Eventually replace the older sony explode headunit with something more interesting and remote controlled so I dont have to unlock the console everytime I drive.
oh yes! How do you haul a kayak on these scramblers ;) since you cant buy a congo cage or equivelent for them?
For your boat towing but not loosing ground clearance....
The receiver tube goes through the rear crossmember and back to a brace between the frame rails. Bottom pipe is same height as frame.
forum
Yak rack
I have been carrying my Hollow form(remeber thoughs) and my twister just straped down on the rollbar with a piece of carpet over the roof. I run straps through the roll bar and each bumper. Not at all ideal but It has worked for the last ten years or so. I am starting to look for a rack though. I do like the bottom of the wind shield frame mount in the front and the spare tire mount in back. Probablly Need to lenghten the overhead though.
Ya I like toaring boats in the 14' range (coastal, lakes) almost bought one this week (tired of renting) but dont have a rack on the YJ either so that is a problem.
No picture updates, still struggling with getting the underside of the body and frame coated. Removed the damaged rear crossmember and fit the replacement. Herculiner gets delayed a week or two thats what I get for living in MD and having the Scrambler back home in fathers shop in PA (have to have facilities).
Update:
Well this weekends project was to herc it, of the last 2 weeks the CJ8 has recieved an almost complete undercoating of POR15 and topcoat (Still have to do around the tranny area, I will do this when I remove the tranny) and the very front part of the frame and under the front fender lips
What has been done, POR 15 and topcoat of the frame and underside of the body up to the engine and front fenders (ran out of topcoat..........) will deal with this in the next week. All patches and most of the body smoothing (I hate to admit it but I had to use a little bit of putty as skin coat here and there but metal was put under it in all areas) is done still have some smoothing work on those rear wheelwell lips that were fabricated.
The Tub has been herculined from the firewall back except the tailgate, I didnt do it yet for several reasons. The herc was rolled and the protectant sprayed on. The inside of the tub was POR15'd with tie-coat primer put over it then herc so hopefully everything will be sealed up nice and tight. I also need to put the replacement rear crossmember on. I still have a long way to go, but at least it seems to be coming along.
Ryan,
Did you fab up that tailgate yourself? I like...
Painted this weekend, not sure what to think. The Light Khaki Metallic went on excellently (except where I got some fuz from a rag on the rear cab corner opps, gravity guns rock!) but I am not particularly happy with the bodywork. You can guess from thee pictures where the problems wer. Nohing like a greenish paint to bring out every flaw. So despite all the metal I welded in I am a junction and have 3 options the way I see it:
1. Let it be, it isnt that bad for the body reconstruction I had to do.
2. Sand the sides down (front clip and rear came out decent), smear a liberal amount of glazing on (used very little) and sand again with my inline, then a block, then repaint. Leaving long thin lengths of putty prime for cracking.
3. Slap functional rocker guards (like Sun performances) and 16 gauge plain steel cab corners on it.
The vehicle is was still a good buy, and will likely be an excellent Jeep even as is. I just have to decide where I am going to take it. More towards a decent looking driver/trail Jeep or more towards a perfect garage queen.
Jeepskate said:
Ryan,
Yep, its just made of 1.25" pipe and has expanded metal on it. It hinges on a pipe in the bed floor. The top of the bed is 1.25" pipe. I used some 1" pipe inside the top pipe of the tailgate and that slides inside the pipe of the bed as a latch that will not open when stuff slams into it. If you look closely you can see the little handles and the slots cut in the tailgate for them.
Update 10/19/2003:
Took a little unauthorized drive, jeeps are best without windshields, doors, headlights, flares, mirrors and various other bits and pieces.
Finished body except for doors and windshield frame. It is now painted in Jeep 2004 Khaki metallic. The entire frame, and most of the body is coated with POR15 then tiecoat primer or black topcoat where appropriate. The tub has been herced and protectant applied (pictures above). Overall the body turned out pretty well with only a little bit of skincoat filler where patches were welded in. However rocker panels did come out with some very minor imperfections (that probably wouldnt bother anyone else) that the new paint brought out. looks "ok" but I am not particularly pleased with it so instead of slathering on liberal amounts of filler to smooth out where I hammered the body back out (damage to the bottom edge) and to smooth out where I had welded a patch on the drivers side, I ordered Sun performance rocker guards figured I would just damage the rockers again anyways.
Next I have to get the doors on, paint the top, get halfdoors and a softop, install the rockers, look at front and rear bumpers, seats, tuffy stereo consoles and a variety of other small parts.
Ah CJ8s couldnt we all just buy a new Jeep by the time we are done but who would want to do that?
