I went through the oil to propane conversion a few years ago. My oil boiler was on its last legs and was rusting out. I did a lot of research and propane was clearly the way to go. An oil burner can not modulate its flame, it's either on or its not. Propane burners can fire up or down based on outside temperature, temperature of returning water through the system, etc with internal computer components as well as what's called an outside reset controller. You can also vent propane burners through PVC and they are very quiet. Plus I don't believe there is as much risk of CO leaks, etc. They also do not really need service, unlike oil burners which need to be cleaned out yearly.
I've definitely noticed a big difference in both cost and performance. People in my area I know with oil are paying upwards of $4 a gallon, whereas I have been paying about $2 a gallon for propane. There aren't as many BTUs in a gallon of propane, but when you factor in the fact that my boiler is 96% efficient where most oil boilers are 80% on a good day, and that it can modulate up and down from like 50k BTU to 150k, you come out way ahead. I have a Triangle Tube wall mount boiler and also have the indirect fired hot water heater, which gets its hot water from the boiler then stores it in this crazy insulated tank that only loses half a degree an hour. One time our electric went out for a couple days, and there was still hot water in the thing days later.
