What other creative methods have you guys used to remove steering wheel?
I have tried:
- standard puller (broke the puller body at edge of center press bolt)
- second standard puller, Matco brand (broke 2 pull bolts in 2 tries)
- third try with Matco puller - drilled and tapped 2 more holes in outer ring to have 4 puller bolts. Rounded off hex on end of press bolt using a 1/2 inch breaker bar with impact socket.
- hit end of press bolt while under load with BFH, really hard, several times.
- worked on end of press bolt, and perimeter ring of steering wheel with air hammer while puller under load
I got nothing, it wont budge.
I thought about heat, but don't want to melt the plastic stuff in the column.
Any other ideas?
Thanks
I have tried:
Any other ideas?
Thanks
